ArchiRADAR Forum => Maxwell Render => Topic aperto da: paperless - 15 Gennaio 2009, 10:39
La NL ha reso disponibile il download alla versione 1.8.1.1 del plugin di Maxwell Render per Cinema4D.
A breve una descrizione (in italiano) delle novità apportate.
Luca
Aspettiamo impazienti la traduzione!!! :peace:
Aggiornamento al volo del plugin. Siamo arrivati alla versione 1.8.1.3
Ecco mi miglioramenti apportati velocemente da JD.
Version 1.8.1.3 of the Maxwell for Cinema 4D plugin has been released. This is a minor bug-fix version:
Changes:
Export now uses either the current Cinema Basic Units, one of several unit presets, or a custom multiplier
The plug-in now supports export of multiple cameras
Fixes:
Polygon objects could become triangulated on export
Render dots were not being respected correctly in some hierarchies
Invert/ Soft/ Image Alpha could be interpreted incorrectly when translating Cinema materials
Auto-generated Instances could be located incorrectly
Maxwell Instances could interfere with Cinema instances
Maxwell Instance objects could show an incorrect bounding box
Maxwell Emitters were not shown correctly in the Cinema viewport
Invalid texture paths would not be corrected if they used forward-slash UNC format
In download ora.
Luca
