ArchiRADAR Forum => ArchiCAD => Topic aperto da: Alex - 23 Marzo 2008, 11:56
Titolo: ArchiCAD 11 upgrade (Build 1200 )
Inserito da: Alex - 23 Marzo 2008, 11:56
..... :shock: altro upgrade per archicad 11...
http://www.graphisoft.com/ftp/techsupport/downloads/ac11/AC11-1200.exe
List of most important bugs fixed in this Hotfix:
65087    CRASH - In navigator, while trying to modify master layout settings with multiple layouts selected.
61159    CRASH - In rare occasions, file is saved with bad data structure and causes crash when opened again.
64468    CRASH - When opening certain legacy ArchiCAD files.
73180    CRASH - When placing certain PDF files as drawing.
66266    CRASH - When splitting several elements at the same time in a Detail view.
65776    CRASH - When Zooming while dragging several elements on a Layout.
70184    CRASH - While editing wall thickness in certain situations.
67090    DOCUMENT - Automatic Dimensioning tool dimensions rotated rectangular columns incorrectly.
66306    DOCUMENT - Automatic Dimensioning with 'Core only' option - full width of composite walls are dimensioned.
67145    DOCUMENT - Deleted segments of Interior Elevation marker still appear on layouts.
68223    DOCUMENT - Door orientation parameter does not update after undoing a mirror action.
69540    DOCUMENT - In certain situations source markers can not be linked to a drawing derived from that source marker.
67965    DOCUMENT - Overlapping column and wall do not miter in layout views, even though on floor plan they appear correctly.
69929    DOCUMENT - Shadow casting  is sometimes wrong when building elements overlap.
68297    DOCUMENT - The text settings of the Interior Elevation marker are reset when the ID number is changed from the Navigator.
70541    DOCUMENT - Zone materials are not listed correctly in Interactive Schedules.
68081    EDIT - Wrong grouping of elements in detail views after 'Rebuild from Source view' command.
70422    I/O - Extra lines appear in PDF outputs in rare occasions.
70584    I/O - In certain files library parts are missing from plan, even though the library parts are loaded.
69057    I/O - In rare occasions, not all pages of a multi-page Interactive Schedule document is printed or saved as PDF.
67771    I/O - Publishing layouts with "selected items" option - the output file will not inherit the new layout name, if it was changed since a previous publishing session.
71726    I/O: Some PDF files placed as drawings appear rotated in PDF output.
66304    I/O: Texts using certain (not commonly used) font types are missing from PDF output. A registry key has been introduced that changes font embedding settings, resulting in larger PDF files. Use only if you are experiencing the problem. Read more at: archicadwiki.com/Bugs/Text_missing_in_PDF
73420    OPTIONS - If Cadimage Door/Window builder add-on is loaded, zone categories are deleted after Attribute Manager is closed.
72406    SPEED - 2D pan and zoom is slow if there are many views in Navigator or Organizer.
72983    SPEED: Creating schedules that list elements in relation to zones is slow if the file is large.
69653    TEAMWORK - External drawings placed in sections, details or Worksheets are missing from Drawing manager after Send and Receive.
71106    VIEW - Feedback lines are missing after certain combination of events.
Titolo: Re: ArchiCAD 11 upgrade (Build 1200 )
Inserito da: antonibon - 23 Marzo 2008, 12:07
 :D :D :D fate attenzione che è per la versione inglese.... quella italiana, già annunciata da qualche giorno, è di imminente rilascio....
