Autore Topic: nuovo hotfix archicad 13  (Letto 5525 volte)
marcomonza
  • Post: 1.038
« il: 02 Marzo 2010, 09:46 »
oggi ho aperto Ac13 e mi ha subito segnalato un nuovo aggiornamento
copio e incollo...
buon lavoro e buona giornata a tutti
List of bugs fixed in this Hotfix*:
*Compared to ArchiCAD 13 Hotfix#2 - Build 3235. If you are upgrading from a build earlier than 3235, please make sure to read the relevant release notes as well!
100360   CRASH: when using undo after placing particular doors
100780   CRASH: When opening certain ArchiCAD 12 files
101300   CRASH: when breaking a hotlink in some circumstances
102628   CRASH: caused by the handling of images on OS 10.6 in some situations
96728   CRASH/TEAMWORK: when releasing all elements in some situations
101825   CRASH/TEAMWORK: when placing and deleting hotlinks in particular circumstances
101479   FILE: data is positioned badly in DWG files' model space
106426   FILE: Can not open some files in which Solid Operation is used between project elements and Hotlink elements
102489   FILE: radial gradient fills exported to PDF have incorrect origins
104748   EDIT: dragging multiple elements in section/elevation results in the same home storey for each of these elements
101524   EDIT: tracker coordinates are incorrect with rotated orientation
102827   TEAMWORK: Slow Send&Recieve changes after updating multiple Hotlinks
103129   TEAMWORK: detached projects can be set to "online" in the Teamwork palette
103169   TEAMWORK: Slow Send&Recieve changes caused by the mailing system
103274   TEAMWORK: long send & receive times in some situations
103542   TEAMWORK: "Server returns error code" while sending or receiving in some specific situations
103912   TEAMWORK: cannot send & receive after placing an XREF under some circumstances
104048   TEAMWORK: hotlinks with SEOs and "skip nested" files are not updated
104973   TEAMWORK: "serious error has occurred" error after send & receive under very specific circumstances
105180   TEAMWORK: Labels can become "Invalid elements" under certain circumstances, preventing users from joining such a project
101085   TEAMWORK: must revert to autosave in some situations
85211   EDUCATIONAL VERSION: One year educational license does not work if the Username contains accented letters
105242   EDUCATIONAL VERSION: "license renewal" button is inactive on some systems
Bugs fixed in optional Graphisoft Add-Ons:
102459   Google Earth: Textures from KMZ files are duplicated
90410   Google Earth: KMZ files are imported at the wrong model size
101154   CINEMA 4D: ArchiCAD doesn't find textures during import if C4D file was saved with certain options
103381   CINEMA 4D: materials with special characters are not grouped
Archicad 27-28 - Windows 11
Re: nuovo hotfix ArchiCAD 13
« Risposta #1 il: 02 Marzo 2010, 10:54 »
Siamo contenti che te lo abbia segnalato *subito*.   ;-)  Ma da quant'è che non aprivi ArchiCAD ?!?   :blink:
« Risposta #2 il: 02 Marzo 2010, 10:59 »
A me ad esempio non l'ha segnalato......
« Risposta #3 il: 02 Marzo 2010, 11:02 »
Antonello ... ArchiCAD 13 Hotfix#2 - Build 3235 è uscito 3 mesi fa ...
marcomonza
  • Post: 1.038
« Risposta #4 il: 02 Marzo 2010, 11:10 »
 :shock: :shock: chiedo scusa Robs, togli pure il post, grazie.
sono stato un mese fuori dall'ufficio tra ospedale e casa per un'operazione al ginocchio che ha causato problemi e continua a causarne visto il male... :(. comunque, in questi giorni sto usando sempre Ac 13 e nei mesi scorsi pure, ma solo oggi mi è uscito l'avviso.
pensavo di essere d'aiuto e invece.....
vabbè, cancellate pure.
ciaooo
« Risposta #5 il: 02 Marzo 2010, 11:19 »
ma figurati ... non preoccuparti  ;-)
borgo1971
  • Post: 440
« Risposta #6 il: 02 Marzo 2010, 11:20 »
Sì, ma adesso c'è la 3259  ;-)
since ArchiCAD 4 now 29 on
MacPro 7,1 12x3,6GHz 64GB ram
MBP 16" 8x2,33GHz 16GB ram
powerd by macOS 13.7.6
simzof
  • Post: 95
« Risposta #7 il: 02 Marzo 2010, 11:21 »
Però ieri è uscito effettivamente un nuovo aggiornamento: ArchiCAD 13 Hotfix#4 - Bild 3259
« Risposta #8 il: 02 Marzo 2010, 11:28 »
Non avevo fatto caso al numero...... però da ieri, come già evidenziato, c'è quello nuovo......
simzof
  • Post: 95
« Risposta #9 il: 02 Marzo 2010, 11:33 »
Che tra l'altro è proprio l'aggiornamento che ha postato marcomonza, infatti la lista delle correzzioni è proprio quella dell'ultimo aggiornamento RISPETTO alla versione 3235  :ok:
« Risposta #10 il: 02 Marzo 2010, 11:48 »
Non avevo visto che c'era un nuovo upgrade... cmq il numero segnalato da marcomonza era sbagliato   ;-)
Ho messo la news in home page.  Thanx  :ok:
p.s. ma la Hotfix#3   è stata saltata di netto ?
« Risposta #11 il: 02 Marzo 2010, 12:02 »
No, è che la numerazione degli hotfix per AC13 è un po' sballata.
Il primo aggiornamento è uscito presto, e solo per poche versioni localizzate, e qualche volta viene contato, altre volte no. Ufficialmente partirebbero dal n.2, ma c'è effettivamente un po' di confusione.
klq
  • Post: 139
« Risposta #12 il: 02 Marzo 2010, 13:39 »
io ho aggiornato il mio ArchiCAD 13 alla build 3259
ora però non mi riconosce l'add-on mesh to roof
ho provato a riscaricarlo dai goodies me niente
a qualcun altro è successo? come ha risolto?
rettifico
riscaricato il goodies ora sembra funzionare
meglio così
« Ultima modifica: 02 Marzo 2010, 14:08 da klq »
« Risposta #13 il: 02 Marzo 2010, 14:11 »
La pagina da cui si scaricano i goodies singolarmente non sembra aggiornata. Se è davvero così, è normale (purtroppo) che quelli non funzionino. Ma l'installer dell'Hotfix di ArchiCAD doveva aggiornare anche tutti gli addon (Graphisoft e Goodies) già installati...
