Nuvo retino
Aperto da blendibani, 11 Febbraio 2011, 13:30
blendibani
salve  a tutti,
qualcuno mi puo aiutare a spiegarmi come posso creare un nuvo retino con Ac12?
qoki55
Cartella "Documentation"
Pagina 1156 ArchiCAD 14 Reference Guide
Create or Edit Symbol Fill
Symbol fills can be created by the user from a sketch drawn in any model window, with the
following steps:
1. Draw a pattern using Lines, Arcs and Hotspots.
2. Select all the components of the pattern and choose Edit > Copy.
3. Choose Options > Element Attributes > Fill Types. Click the New. button, enter a name for the
new fill and select the Symbol fill radio button, then click OK to set the name and type.
4. In the Edit Symbol Pattern panel, click the Paste button above the Preview window. The
pattern appears in the Preview window. Check the Show Pattern Unit box to highlight a
single unit of the pattern in the preview window of this dialog box.
Note: If the selection of copied components includes splines, fills, text or other elements,
these will not be pasted into the Fill Types dialog box.
5. Use the controls in the Fill Edit Symbol Pattern Panel to set the size, pattern and rotation
angle for the symbol fill.
6. Click OK to exit the dialog box and save changes.
Note: The fill's screen-only bitmap pattern must be edited manually in the Fill Availability
and Screen-Only Pattern Panel.
If you wish to change a symbol fill after the original components have been deleted from the
window you copied them from, you must first choose the symbol to be edited within the Fill
Types dialog box, and press the Copy button. By pasting the symbol fill back into the window, it
becomes editable once more.
Windows 10 Pro_64
Jonathan
Citazione da: qoki55 - 11 Febbraio 2011, 15:32
ArchiCAD in inglese? :wondering:
ArchiCAD 18 - AutoCAD 2016
qoki55
Si. Non sono un Italiano e non vivo in Italia.
Windows 10 Pro_64
Jonathan
Citazione da: qoki55 - 11 Febbraio 2011, 19:31
Ad ogni modo scrivi abbastanza bene: complimenti, però forse non tutti conoscono l'inglese come tu conosci l'italiano. ;-)
odama
#5
Ti mostro un tutorial veloce se vuoi utilizzare un retino con un'immagine reale...segui i passaggi:
-clicca su OPZIONI nel menù in alto-->attributi elemento-->tipi di retino
-clicca su NUOVO e gli dai il nome che preferisci. (passo 1)
-vai su CARICA IMMAGINE e prendi dal tuo computer il retino immagine che vuoi mettere. (passo 2)
blendibani
Grazie ragazi, molto chiari.
