Sono alle prime armi con Archicad
Aperto da artemisclark, 12 Aprile 2023, 12:27
artemisclark
How to Choose the Best Medium-Duty Pressure Cleaner: Guide and Recommendations
Medium-duty pressure cleaners are the most popular choice and, often,
The Best Rated Pressure Washers Reviews: TOP 10 Best Pressures Washer, as they are suitable for families. They are reasonable in price and are getting stronger in terms of power. In addition, they are quite versatile, they can handle both light-duty jobs and heavy-duty cleaning.
You can find either electric or gas versions of medium-duty pressure cleaners, with pressure ranging from 1,700 to 2,800 PSI and prices from $120 to $350.
This review includes some general guidelines for the usage of medium-duty pressure cleaners.
Gas or Electric?
This is a hard question to answer and it may require additional information before you make your final decision. Here, we list several of the main features of electric and gas cleaners so that you will find it easier to choose the best pressure cleaner for your own needs.
  • Electric
One of the biggest advantages of electric products compared to gas ones is that they do not require trips to the gas station. However, electric products have cords, which can limit their range. For this reason, the electric pressure cleaner is preferred by people who will be doing more indoor cleaning, as an electric outlet will always be nearby.
Moreover, an electric-style washer will be friendly to your ears because it is much quieter than gas ones. This seems like a minor point but if you will be cleaning for several hours, this factor may drive your decision.
In terms of price, an electric-style washer is more budget-friendly, though it is also less durable.
  • Gas
Obviously, a gas-style washer needs gas for fuel. However, you will not be bothered by an electric cord. You can clean anywhere, even very far from your house. Moreover, gas-powered engines are much more powerful and durable than those powered by electricity.
In terms of the cons, the smell and noise are the most common complaints about gas pressure cleaners. Moreover, they cost more than electric products on the market, as well as require more maintenance.
What is the top pressure cleaner powered by gas?
Generac 6922 2,800 PSI 2.4 GPM
Generac introduced a new line of residential pressure washers that is on the list of Best pressure washer on the market. Generac’s 2,800 PSI and 2.4 GPM model offers great performance, a good value for the money, and a robust design.
For less than $300, you can have one of the best gas-powered medium-duty products on the market.
Generac’s 2,800 PSI and 2.4 GPM model features a high-quality OHV engine that is strong enough for even heavy-duty cleaning and is very stable. It can last for years.
The performance is quite diverse owing to the design of four quick-change nozzles. Basically, it can handle all kinds of cleaning, from blasting to spraying, and it allows you to switch smoothly without worrying about over-applying pressure on the surface.
What is the best medium-duty, electric-powered power washer?
AR Blue Clean AR383 1,900 PSI 1.5 GPM
Like most electric pressure washers, this model is much cheaper than gas-powered ones. The awesome AR Blue Clean AR383 costs only $150 -- a small amount of money for a washer with 1,900 PSI and 1.5 GPM. Hence, many consider this the best value pressure washer on the market.
Though its motor is just a universal one, the pump is really high quality, as it is made of aluminium. This product is perfect for indoor use because it is quiet and creates no smoke.
Conclusion
If you have a family, medium-duty pressure cleaners are the most suitable options for you. You will need to choose between a gas or electric cleaner; we hope What is the best pressure washer will help you make that decision.
Se hai usato i moduli NON hai importato un bel niente, hai collegato un file esterno.
Quindi devi non aver cancellato il file sorgente (quello con la facciata), altrimenti non lo vedrai più all'interno del file principale.
Se l'hai cancellato e non hai copie ... addio ...  :occhioni:
Se l'hai spostato o rinominato allora devi solo ricollegare il percorso perchè, semplicemente, non lo trova più. Per ricollegarlo basta che vai nel menu "Archivio-->Contenuto esterno-->Gestore Moduli Collegati..." selezionare il nome del file dove hai la facciata e cliccare sul pulsante "Ricollega..." in basso a destra. Dopodiché non ti rimane che selezionare il file per localizzarlo.
